Gigabyte GA EX58 UD5 + Antec 1200 case
11 Mar 2007
Hi
just got the bundle from OC and when installing my Nvidia GTS 250 cards in 3way SLI the last card wont go in because there is no way no way of securing it.:(
Is there a case out there where this new board and all my cards will fit in:confused:
Cheers Jorel
PCI-E cards are secured partially by the mechanical strength of the slot, but primarily by being screwed to the chassis at the end where you plug the cables in. This isn't a mistake I'm aware of anyone making.
My best guess is that you've bought dual slot graphics cards and are trying to put one in the lowest slot. I didn't know the 250 was dual slot, but if it isn't your post makes no sense. This requires a case with eight pci slots cut out the back. I believe the Antec 1200 has seven.
My akasa omega has eight slots. All you're looking for is a large box covered with flashing lights with eight slots in the back. You should be able to count these from a photo if need be. I'd look to Silverstone.
I feel it has to be said, tri sli with gts250 makes very, very little sense. I'm sure you have your reasons for going down this road, but perhaps a better solution is to just use two of them, or to replace one with a single slot version.
Yup, the GTS250 is dual slot Jon, and you're right, he's trying to run 3-way SLi in a case with only 7 expansion slots.
