- 24 Aug 2007
Hi,
Just bought an i7 920do and adjusted some settings to overclock. The problems i that if the PC doesn't like the OC it will turn off, then back on, then back off and just loop. I have to take the video card out to reach the bios battery, remove it etc etc
It's a real pain! What could i be doing wrong? Windows sets the vcore to 1.274 so i set it to much the same using 200x20 etc
Is it resetting due to a lack of vcore or could it be something else?
If i leave voltages on normal and just use 200x20 windows boots and primes fine, but it may be overvolting using 1.365
Any help would be much appreciated as i cant put the pc back together properly until the overclock is sorted!
my c0 seemed easier to clock!
