Hey everyone.
Any GA-G31M-ES2L owners out there? Need your help...
I seem to have got a problem with the Socket 775 Gigabyte GA-G31M-ES2L mobo.
First off, Im totally confused by the SATA settings in the Bios,Ive got the latest bios, version FI is it? Ive got one Western Digital SATA HDD and a SATA DVDR drive. Which setting should I have it on??? Combined? Non Combined? Enhanced?....So heres the problem, when I try to fresh install Windows XP, all seems to go fine. I get into Windows, install mobo drivers, gpu drivers etc. But then, at some point on a system restart it will fail and give me the 'System' file (in Windows\System32\Config folder)is corrupt or missing. I try a recovery etc but nothing sorts it. So, reformat, try again. Same problem.
Ive set the comp up on bare minimum, and it just dosent want to play ball. The thing is, I think its the SATA settings in bios, I dont think I have them correct cos the GPU works fine after driver install, the HDD partitions and installs things fine and the DVD drive spins up easy to install XP. Now apparently the mobo can emulate the SATA drives as PATA drives (by setting the confusing bios SATA settings), hence I didnt use a SATA driver disk on the fresh install of XP. The Windows install setup found the HDD and created partition etc. Im stuck
Is the mobo borked?
Also, maybe a bit off subject, does anyone elses mobo take a while to post when RAM is in Dual Channel?, with one stick it flies in POST, but with Dual it takes a bit longer to beep and show the first screen when it detects the drives and continues into XP startup.
Any suggestions? Any help would be mucho appreciated.
