Just built an HTPC PC with following specs:
Gigabyte GA-G33M-DS2R
2GB OCZ Platinum XTC V2 PC-6400
E6750
ATI HD2600XT
The problem I am getting is when i turn the machine off and leave it off for a while, when I turn it back on it looses it's overclock settings.
When i first turn it on, it posts as normal showing the overclock still in place, and then resets itself again and then posts again showing it's lost all the oveclock settings. I then have to go back into bios and resave the settings. the settings are still there but it switches the CPU clock control back to default so have re-enable the manual setting to re-enable the overclock.
Has anybody had a similar problem or got any idea what the issue might be? Is my board faulty?
Any help much appreciated!
E6750
ATI HD2600XT
