Gigabyte GA-G33M-S2H
il Conte said:
Does anyone know when the Gigabyte GA-G33M-S2H matx board, as featured in the below Tom's Hardware article will be available in the UK?
It is available for £69.00 with 18 in stock, unfortunately its not available from Overclockers at the moment. :(
the standard s2 is in stock in oc only difference being it has no esata or firewire, but both are on th4e motherboard pin headers so if you have a case with one its easy to fit up.
i would suggest getting one of these boards, i have one and i really can fault it at all just purchase a seperate back panel for a few pennys
