I have also posted this message here but this possibly a better place and better title.
Just put together my new build and I have a strange memory issue.
System Specs
i7 860
Gigabyte H55N-USB3
Corsair Value 2GB DDR3 PC3-10666C9 1333MHz
Corsair Value 4GB DDR3 PC3-10666C9 1333MHz
The problem is Windows shows 6.00GB installed but only 3.96 GB useable. I am running Windows 7 64bit and the ram shows as 6GB useable in my AMD system. The ram also tests as fine.
I have tried forcing it to use 6GB of ram using MSCONFIG. I also have no onboard GPU so thats not the issue.
Its single channel ram but it should all be usable.
Could I have a faulty memory controller in the i7 860 I bought from MM?
If I put both sticks of ram in the PC it will boot and the maximum amount shows as installed but only the memory from one dimm is usable. If I only put the ram in the second dimm the PC wont boot. The ram tests fine in another PC. If I put just one module in the dimm nearest the CPU the PC boot but only a small amount of ram is usable by the system. For example right now its showing as 4GB installed (1.86MB) usable.
I guess the problem is quite similar to this.
Any ideas?
System Specs
i7 860
Gigabyte H55N-USB3
Any ideas?
