- 11 May 2013
Just powered up my first completed build with the GA H87-HD3 MB.
Everything working, HDD idling, all fans going, GPU fine etc, pretty pleased. Went through the BIOS menus seeing what's what and all looked good except I noted that under "PC Health" only the CPU fans and System Fan 3 (the rear exhaust) were reporting RPM info.
System fans 1 and 2, set to the default Normal ie. PWM control like the others, are both pairs of Akasa Vipers (2 x 120mm/2 x 140mm). They're connected to the MB by Akasa PWM Y splitters and both pairs are spinning, just not reporting RPM status.
I tried them on Silent and Manual (x1.0) modes and they changed speed fine so they're apparently working correctly but still no RPM report. However when Full Speed is selected immediately the RPM for both appears.
Obviously I've tested the connections and I've also disconnected one of each of the pairs and re-tested with the same results. About the only thing I haven't done is remove the Y splitters and tested each of the fans plugged directly into the MB headers.
If this were a particular problem with the Akasa Y splitter why is the Full Speed RPM being reported and why isn't it affecting the two CPU Akasa Viper fans which are also connected through another Akasa Y splitter to their header?
Questions:-
Is this something that is likely to be fixed after installing the OS and then the MB drivers? It just seems a bit unlikely that would fix it since the other fans are reporting RPM OK straight out of the box.
Is there any cause for concern? It does appear to be a specific reporting issue only, otherwise the fans seem to be working as intended.
What I don't want to discover later is that there are some known problems with the 1 and 2 sytem fan headers with this MB and have to dismantle the whole thing to get it sorted. I've searched online and can find no similar recorded issues so that's why I've come here for advice.
Questions:-
