Gigabyte GA-N680SLI-DQ6 review at Anandtech.
Caporegime
6 Dec 2005
Birmingham
http://www.anandtech.com/mb/showdoc.aspx?i=2936&p=2
Market Segment: High End Enthusiast - $279.99
CPU Interface: Socket T (Socket 775)
CPU Support: LGA775-based Pentium 4, Celeron D, Pentium D, Pentium EE, Core 2 Duo, Core 2 Extreme
Chipset: NVIDIA 680i SPP (C55XE) + 680i MCP (MCP55PXE)
Bus Speeds: Auto, 100 to 650 in 1MHz increments
Memory Ratios: Auto, Sync, 1:1, 5:4, 3:2
Memory Speed: 400MHz~1400MHz in various increments
PCIe Speeds: 100MHz~150MHz in 1MHz Increments
Core Voltage: Auto, 0.68750V to 2.375V in 0.00625V increments
FSB Options: Auto, Linked, Unlinked
CPU Clock Multiplier: Auto, 6x-11x in 1X increments - Core 2 Duo, downwards unlocked
Core 2 Extreme 6x-16X
DRAM Voltage: Auto, +025VV ~ +.775V in .025V increments
DRAM Timing Control: Optimal, Expert - 10 DRAM Timing Options
NB Voltage: Auto, +.05V ~ +.20V in .05V increments
SB Voltage: Auto, +.05V ~ +.35V in .05V increments
FSB Voltage: Auto, +.05V ~ +.35V in .05V increments
HT Link Voltage: Auto, +.05V ~ +.35V in .05V increments
Memory Slots: Four 240-pin DDR2 DIMM Slots
Dual-Channel Configuration
Regular Unbuffered Memory to 8GB Total
Expansion Slots: 2 - PCIe X16 (2-x16 electrical for SLI or Multi-GPU)
1 - PCIe X16 (1-x8 electrical)
1 - PCIe x1
3 - PCI Slot 2.2
Onboard SATA/RAID: 6 SATA 3Gbps Ports - 680i MCP
(RAID 0, 1, 0+1, 5, JBOD)
4 SATA 3Gbps Ports - JMicron JMB363
(RAID 0, 1, 0+1, JBOD)
Onboard IDE: 1 ATA133/100/66 Port (2 drives) - 680i MCP
Onboard USB 2.0/IEEE-1394: 10 USB 2.0 Ports - 4 I/O Panel - 6 via Headers
3 Firewire 400 Ports by TI TSB43AB23 - 1 I/O Panel, 2 via Header
Onboard LAN: Marvell Gigabit Ethernet - PCI Express - 88E1116 PHY - 2 ports via 680i MCP
Marvell Gigabit Ethernet - PCI Express - 88E8056 - 1 port
Marvell Gigabit Ethernet - PCI Express - 88E8052 - 1 port
Onboard Audio: Realtek ALC888DD - 8-channel HD audio codec
Power Connectors: ATX 24-pin, 8-pin EATX 12V, 4-pin 12V Molex
I/O Panel: 1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Serial Port
1 x S/PDIF Optical - Out
1 x IEEE 1394a
1 x Audio Panel
4 x RJ45
4 x USB 2.0/1.1
BIOS Revision: Award F3B
Board Revision: v1.0
Cheers
Azza
