Gigabyte GA-P35-DS4 and Audio Question
29 Sep 2004
Wilt of the Shire
I've got the revision 2 model of this board and have had it for some time. I'm using the onboard audio and it's working fine. However, I now want to use the front audio connector of my antec P180 case so I can use headphones to play games without disturbing the wife.
Inside the case are 2 sets of headers, one is a complete block and the other is made up of single pins. Which one do I plug in to the MB header so I can use the fronts ports? Also, the single pins are labelled differently to the ones mentioned in the MB manual, don't want to put them in the wrong way and do any damage!
Not to worry (nobody has anyway :( ), sorted it. Plugged the single pins in and got the headphones working now.
