are you talking about the cooling plate on the back of the board ?
No, I am talking about These heatpipes/heatsinks on the actual surface of the board.![]()
oh ok. Well i used a Thermalright Ultra-120 on the last build i did with a GA X38 DQ6![]()
Can that be mounted both horizontaly and verticly?
A bit confusing I thought, but if the whole has to come off, I would be of the opinion (like you) that it is a bit much!I was under the impression It was just the mobos backplate that needs to be removed?
edition as seen in the p35 rangeWhat 3rd party CPU coolers (air) will fit the Gigabyte GA X38 DQ6 without having to remove any of the cooling pipes?
It would be used with a Q6600, which would be overclocked.
Thanks.![]()
