GIGABYTE GA-X58A-UD3R ARRIVING MONDAY
17 Oct 2002
Stoke
Gigabyte's new entry model X58 with USB 3.0 and SATA 6Gbps is fully loaded with other features and at a much lower price than the higher end boards I personally think it's great value for money.
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard @ £159.99 inc VAT
Based on the Intel X58 chipset, the Gigabyte GA-X58A-UD3R delivers all the killer next generation features that gaming enthusiasts and power users have been waiting for including Gigabyte's 333 Onboard Acceleration features with support for USB 3.0, SATA Revision 3.0 (6Gbps) and a 3x USB Power Boost, as well as multi-GPU support for NVIDIA 3-Way SLI and ATI CrossFireX and support for Intel's high performance processors offering a high level of future CPU headroom for users wanting to maintain cutting-edge levels of performance. With the memory controller integrated directly into the processor die, the Gigabyte GA-X58A-UD3R also supports triple channel DDR3 memory for blazing fast memory performance.
- 2x USB 3.0
- 2x SATA 6Gb/s (RAID 0 and 1)
- CPU: Intel Core i7 Processors (Socket LGA1366)
- Chipset: Intel X58 Express / ICH10R
- Memory: 6x DDR3 DIMM 2200 / 1333 / 1066 / 800 MHz (Max. 24GB) / Tri-Channel / Intel Extreme Memory Profile (XMP)
- Expasion slots: 4x PCIe 2.0 x16 Slots, 2x PCIe x1 Slots & 1x PCI Slot (Supports ATI CrossFireX & NVIDIA SLI Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 8x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- LAN: RTL8111D Gigabit LAN
- Audio: ALC889 8-channel High Definition Audio CODEC
- 10x USB 2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £159.99 inc VAT.
ORDER NOW
are this board good enough for 4ghz overclocked ? I just wish that all manufacturing of stop making floppy ide as we all don't use this anymore! waste of money for unused floppy ide on the board.
This board is good at cheap price but question is are these better than ex58 ud5 board ?
We have reached 4.00Ghz with these quite comfortably. :)
If it is better than the UD5 or not we will have to see, bit early in the game to call it at the moment.
nice price, was thinking of getting the new asus premium to get usb 3.0 ect but maybe this will do all i need and save me ~£100, need some reviews to read through
This sound to be good exspecially all of us (the i7 core member) will be able to grab the cheapest board but hopefully it will be better than UD5 board !
Wow, 4 Pci slots. Bit over kill:P
But doubt you'll be able to fit for cards in there.
Once again they didn't include the site of grahpics cards for this board.
Shame on them.
what do you mean? is this smth to worry about?
Most high end graphics cards are dual slot because of the coolers. But with three of the PCI-E x16 slots right above each other, if you really wanted 4 cards in SLI/Xfire, you would need to have a flat 1 slot card in two of the slots, three if you need to use the PCI slot for something like a wireless/sound card.
But on the other hand, where else can you put the slots? There's only a limited space, so there's not exactly much choice, is there?
ahh i see, thanks for the info. shouldnt interfear with my eventual 5870 x 2 setup
I disagree with this sentiment. I use a floppy drive and wouldn't be without it, dos on usb has proved far from reliable so far. I also use a pata optical drive occasionally, but sata optical drives are readily available so this is less important to me. USB floppy drives are an option, but I can't help but feel skeptical about booting from one.
Glad to see the UD3R's replacement has six dimm slots.
No word on the EX58A UD5 yet??
Gigabyte have it showing on their website, so I assume it will be hitting the shelves here soon?
We have it on test at the moment and it in overclocking and value terms is blown out of the water by the EX58a-UD3R. :)
