I could do with a bit of advice here if anyone could help, after spending a chunk of money on decent hardware for an I7 setup I have had no end of problems with this motherboard, it just will not recognise memorry correctly.
It either does not pick the full amount up in the BIOS or it says in window that 12 gig is installed but only 8 gig is useable, on reboot it will then be fine, then next reboot it will again show memory issues of some sort. I even doubled the memory to get another set to eliminate faulty ram but had exactly the same issue with the second set, any ideas?
