I Just buit a new PC and am having loads of problems mainly with graphics.
Initiall I was getting a blue screen and then Windows wouldn't load, I had used an old HD with Windows 7.
I put up a post and had some excellent help as below....
yh you'll need to set sata ports from ahci mode to ide mode then it should let you boot into windows then you can run this reg tweak from within windows and reboot into bios set sata ports back to ahci mode and it wont bsod then
http://cdn.ithinkdiff.com/wp-content...09/05/ahci.reg
your old windows/install wont have the needed ahci drivers hence its bsod'ing and newer modern board default to ahci mode for the sata ports now
This seemed to fix things, but I continued to have problems loading Windows.
So I bought a new SSD and put a clean install of Windows 7 on it.
I have removed the Radion R 290 GPU to eliminate it.
Problems still continue the same using the onboard graphics.
I can hear the POST beeb but 50% of time there is no BIOS menu displayed and I just get a black screen. However, I do hear the windows tune so know the OS has loaded.
I plugged one screen into the D sub and one into the DVI -D and
reset the CMOS. Sometimes I get a display on both screen and sometimes only on the D sub.
Now the USB keyboard doesn't work, but a PS2 one does ( keboard tested in another PC and is OK).
After closing down the PC it doesn't boot properly unless I switch the power off first on the PSU!.
Is the mobo faulty or is there anything else I can try before sending it back to Overclockers ?
