Gigabyte GeForce RTX 3070 Ti GAMING OC
25 Aug 2015
Warwickshire
Anyone know of Waterblocks for this card?
3070ti blocks don’t seem to be prevalent (at least via google) and those that I can find seem to support specific iterations.
I did a quick look on EK , Alphacool and for Barrow and cannot see a waterblock that fits that card. If you email gigabyte you may get an answer as to whether there are any available or contact EK/Alphacool directly to see if they know any better.
Is best to stick with certain brands if you are planning to watercool. Asus Strix cards are well supported and also TUF as well because the PCB layouts are normally the same. Gigabyte seems to have the worst support but if the card is using the generic PCB layout the waterblock for another card may fit it. There is a Alphacool block for a KFA2 card and they are normally use the standard PCB so if it is it would be suitable for other manufacturers if they are using that PCB. You need to contact the manufacturs to get a solid answer or look for PCB guide for those cards.
Here is pcb for your card. TY Techpowerup.
KFA2
Doesnt look the same to me so wouldnt risk it.
