- 7 Dec 2012
- Letchworth Garden City
Is it wishful thinking that I’ll be able to fit the Gigabyte GeForce GTX 770 WindForce in my Lian Li PC-7FNWX.
The Windforce card is 292mm long, the case allows for a max of 290mm near the disk cage area and 430mm above.
Dam you extra 2mm!
The reason I query is the top PCI-E slot on my MB falls in-between these two zones, if the longest part of the card is at the top near the PCB I’ll be ok.
*Edit* From this side profile shot its actually longer at the bottom so its definitely going to cause issues. Dam.
My Case http://www.overclockers.co.uk/showproduct.php?prodid=CA-193-LL&groupid=2362&catid=187
Info from Lian Li http://www.lian-li.com/en/dt_portfolio/pc-7fnwx/
Any advice would be super appreciated
Dam you extra 2mm!
