Gigabyte H55N-USB3 - disabling onboard gfx?
2 Mar 2009
Nottingham
I recently bought this M-ITX board and installed an i3 560 and 4GB Corsair RAM.
The BIOS sees all of the RAM, as does Windows 7 (64-bit), but it can only use ~3.75GB.
Is this something to do with the onboard graphics on the i3 chip? I have a Radeon 4870 1GB installed as the primary display device so assumed that the CPU wouldn't take up any RAM?
There is a FRAME-BUFFER setting in the BIOS, but you can't disable it completely.
Any ideas??
I think that some of your ram is being allocated to the GPU anyway. Not sure how to disable that. On my M-iTX board like your one that I had in my HTPC system I had the same thing with a HD4550 card. But since it did not make any difference to the performance I did not worry to much about changing or finding out what or why.
Agreed that it will make very little difference, if any at all.
Just one of those things that bugs me! I don't care if I can't change it, I just wanna know what it is!
So true bugs me too. Have subscribed to this thread in case some wiser head has an answer for us. :)
Am gonna have another look tonight - something to do with the FRAME-BUFFER option in the BIOS I reckon. I think you can decrease it but not disable it.
I've already selected the BIOS option for use PCIe graphics primarily, and don't bother with integrated graphics.
That extra ~250MB might be needed one day.
Perhaps.
Probably not...
Still - bugs me :D
Glad to hear it's not just me!
