The above application isnt supplied with Haswell boards.
Now you are confusing me even more.
Are you saying " Hybrid Digital Power Engine" isn`t supplied with GB Haswell boards. If so, why is it advertised on the H87M-HD3 board. Just wanting to know if this board is capable of OCing, as I can`t seem to find any reviews or mention of it.
And thanks for the responses guys.
http://www.gigabyte.com/products/product-page.aspx?pid=4517#ov
he means the application/program 3d power
you also have to be carefull with the h87 and budget boards as they skimp on the bios/oc features so you would need to google or search on how much it will oc
the cheap z87 d3hp http://www.overclockers.co.uk/showproduct.php?prodid=MB-437-GI&groupid=701&catid=5&subcat=2574 would be a good budget ocing board imo
