Just got one of these for my new quad core system and the thing is being a pain with the boot. It will only boot from the HDD with a Win 7 install.
If I try a USB drive (that boots fine in another machine) we either get one of two things
1) If its in the front panel then the keyboard is disabled and you cant select the USB drive in the first place (from the boot menu).
2) If its in the rear panel then it tries to boot from the USB and throws a 'Boot Error'.
If I try to boot from the IDE CD then I get 'Insert System Disk'.
I am trying to run a memtest and have set F4 Optimised Defaults and only amended the RAM settings to the correct values (I have Corsair Dominator 8-8-8-24 @ 1600, the auto detect tries to run it at 9-9-9-24). Legacy USB support is on as is USB Keyboard Support.
Anyone have any ideas please ?
