It does get hot but doesn't affect overclocking a great deal. Worth having a silent 80mm fan covering the board/chipset/memory anyway.geff_r said:Well my only problem with the ds3 is the cooling
the northbridge heatsink looks very cheap
The ds4 is £10 more than the ds3p so why bother? just get the ds4?Servo said:I have the DS3 with a 6300 @ 460 fsb, fully stable, and no extra cooling.. I'm sure the cpu will go higher. but my ram is geil 5300 running @ 920.
I've tried a few other boards, including the Asus p5n sli plus, and none compare to the DS3.
On tuesday I will have the new DS3P, which really is the DS4 without the heat pipe.
geff_r said:The only 3 boards worth considering now after a massive amount of research
seem to be
Abit ab9 quad gt
Asus p5b deluxe
Asus commando
Everything else seems to have a yea but when you look deeper.
erm the commando has reports of going way over 500 fsb as does the quad gtsnowdog said:Abit: nvr read much info about it, how does it clock?
p5b deluxe: good board yes, p5b vanilla is fine though too seen a guy @ 4 ghz on it (with a c2d 6400)...
Commando: overpriced p5b with lcd on back and bragging rights ''republic of gamers'' imo
geff_r said:erm the commando has reports of going way over 500 fsb
geff_r said:as does the quad gt
