i have been planning to upgrade my ram, as the first part. (some say its unnessisarry buy hey..its an upgrade)
however i have read this
"Because of chipset limitations, when using FSB 1333 MHz CPU with populating
all DIMM sockets, memory frequency will be reduced from the original, and
system instability or incorrect detection of memory module may be occur."
"Because of chipset limitations, do not populate both DIMM sockets of the
same channel (e.g. DDRII1 and DDRII2), or populate 4 DIMM sockets with
double-sided memory modules to prevent system's failure to start or
incorrect detection of memory modules."
i am planning to upgrade to this DDR2-1066
http://www.overclockers.co.uk/showproduct.php?prodid=MY-039-KS&groupid=701&catid=8&subcat=817
any suggestions?
EDIT* this has just been put onto "one week only" offer
http://www.overclockers.co.uk/showproduct.php?prodid=MY-096-GL&groupid=701&catid=8&subcat=813
would this be compatible, and also how do i change the memory frequency in BIOS?
any suggestions?
