Hi there.
I just have a few questions about this board I have.
1) After overclocking my CPUfsb to 333mhz, the lowest I can set the memory divider to is 2, which is the 667mhz limit of the memory. I have now pushed the CPUfsb to 350 and the memory has gone to 700mhz and the timings are now 5.6.6.16. Is there any way to get the divider lower than 2 to keep my memory timings a tad tighter ?
2) Why aren't the volts listed ?
Everything just says "normal" and you have the option to up them in 0.2v increments or whatever. Nowhere tells you the actual volts for anything other than the CPU
Ummmm.... I think that's it for the mo
