Gigabyte P57W-CF2 issues
24 Dec 2006
GB
Had it 2.5 months. Very light use so far on GTA V. It has a 256Gb M2 SSD and a bigger, older tech HDD. I would like to replace the HDD with another SSD, say 500Gb. Can someone recommend a suitable one please? Preferably one which includes a clone function.
Hi pattojones,
The unit we would use if we installed at build stage would be this:
Description
512GB 2.5" SSD SATA 3
Transcend PN
TS512GSSD420K
Hope that helps,
Regards,
Gigabyte UK NB Team
Great! Please can i have a link to order one?
Hi pattojones,
We are unable to see the product listed on OcUK, so cant post link.
Also cant find the p/n listed anywhere on line..... probably the reason for your request for a link !
We are asking HQ if they have another part number or reference and will endeavour to come back with something more helpful asap.
Regards,
Gigabyte UK NB Team
OK, so HQ inform us that the part number we quoted is an OEM part and not retail. Making a purchase of the same brand and "512GB 2.5" SSD SATA 3 " format should work fine.
It looks like this is the correct part number: TS512GSSD370
Hope that helps,
Regards,
Gigabyte UK NB Team
