Hi
I have the above motherboard (not the B3) in the pc in my sig. A few weeks ago I started to have startup issues. Sometimes the 'detecting drives' screen would pause for a couple of minutes before continuing, and windows would do the same at the Starting Windows step. Windows would usually come up in the end. This got gradually more common and I noticed that windows had stopped detecting the cd drive and a small storage hdd.
After narrowing down I'm sure the problem is the sata2 ports on the motherboard. This model has two sata3 ports which i use for my ssd and main hdd and these are functioning as normal. I have swapped things around in all manner of combinations and everything works on sata3 but not sata2.
This is not something i can work around as i have software i want to install to the main hdd on cd/dvd and i can't do this with 2 functioning ports.
Do you good people think this is a manifestation of the famous SB chipset issue, or could there be another explanation?
-I have the F5 bios.
