- 11 Dec 2005
- Cheshire
The Gigabyte Radeon R9 290X OC WindForce 4GB Graphics Card has earned the "Must Have" award from KitGuru!
"A mighty challenger for Sapphire. The Gigabyte card is quieter out of the box, but runs a little hotter." - KitGuru
Read the review here: http://bit.ly/K1VBIx
Gigabyte Radeon R9 290X OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929XOC-4GD) @ £479.99 inc VAT
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK,FAN, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Supporting multiple independent display outputs simultaneously, AMD Eyefinity technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- WINDFORCE 3X 450W cooling system
- Core Clock: 1040MHz
Specification
- GPU: Hawaii XT
- Stream Processors: 2816
- Core Speed: 1040MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: WindForce 3X 450W Cooling System
- PCI-Express X16 lane required
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required <
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Card size: L=294mm, W=141mm, H=41mm
- Warranty: 3yr
Only £479.99 inc VAT.
ORDER NOW
