I need to RMA my sons R9 270, the fan shroud has a very, very loud rattle eminating from it. Have placed some light pressure onto the shroud and the rattling stops. Think it could be a quick fix with replacing the fan casing.
I went to the Gigabyte RMA bit and it said to Contact the Original Seller.
Is there anyway I can avoid this? I have spoken the to eSeller before regading this issue, they were bordering on rude and not at all helpfull (not OcUK, sounds a lot like Scam).
The item is inside the warranty peroid at just under a year old.
Thanks chaps.
Thanks chaps.
