Gigabyte Tool to Check 6-Series SATA Issue
30 Mar 2010
Under The Stairs!
Gigabyte has released a utility that works on any motherboard (of any brand) that uses Intel's defect-prone 6-series chipsets (such as P67, H67), and checks if the installed hard drives are connected to defective SATA ports, or whether the board is prone to defects at all.
Source:
http://www.techpowerup.com/139999/Gigabyte-Gives-Out-Free-Tool-to-Check-6-Series-SATA-Issue.html
Gigabyte Utility Download Direct link:
http://download.gigabyte.eu/FileList/Utility/mb_utility_6_series_sata_check.exe.ZIP
This seems incredibly useless.
This is what I get when running it:
Yes I am fully aware of that but my SSD and HDDs are occupying all four SATA 3 ports so I have nowhere else to put my optical drives. :rolleyes:
so basically it tells you if you have devices connected to risky ports
if it comes up with nothing, its all good >>! obviously...
yes? am i being thick
That's as much as I got from it. I was half expecting it to analyse my chipset and then tell me it'd need replacing as opposed to just telling me where I'd plugged my SATA cables in!
It'll be useful for people who may have bought closed systems recently, or don't fancy opening up their case to see what ports devices may be connected to. Beyond that, it's not really much use.
I guess it probably is, but assuming it works on notebooks with this chipset (where most users wouldn't be expected to know, and in many instances will find it difficult even confirming for themselves - e.g. warranty void if case opened, etc) then it could be useful.
e: Beaten by Davey
Can I plug sata2 devices into sata3 ports without any problems? My SSD, HD and optical drive are all sata2.
Yes.
Put your SSD and HD onto the SATA3 ports (if you've only got a couple) and the optical drives on the SATA2 ports - that way, any issues you may encounter may only prevent reading of an optical device.
Cool, will do that thanks. I've only the 3 drives (1 SSD, 1 HDD, 1 optical) in total so probably won't bother to send my asus mobo back. If I ever upgrade the HDDs it will a replacement rather than an upgrade so shouldn't ever need more sata ports.
Its quite literally just made for retarded people who can't read the manual and don't know which port is which, lame tool to say the least.
Frankly theres tools out there, error's in communication are NOT new, they happen on any port, the problem with the Intel chipset issue is these error's increase dramatically over time till the port entirely fails to pick up useable data.
You can use several hdd monitoring tools to read error rates, several of the benchmarking tools do it, and several monitoring tools have hdd parts to them.
Load one up, and periodically check error rates on the sata 2 ports if you want to.
Would this mean that only the two ports shown in red are defective ?
Doppleganger's pic shows all ports in green so all his ports should be ok ?
All the tool basically does is tell you if you have any SATA devices plugged into the 'potentially' affected sockets.
Doppleganger isn't using any of them thus all are green, whereas gcaster is using two of them (the ones in red).
As others have said, its not a test for problems AT ALL, it can not detect faults, or issues, or failures, it merely checks if you have a hard drive connected to a port that COULD fail or not, this is every single sata 2 port, if you have something connected to a sata 2 port it will recommend you move it, if not it says everything is ok, its not capable of testing anything more complex than that.
