Gigabyte Tweak Launcher
6 Jan 2013
Yorkshire
Hello, just wondering if anyone has managed to get it working on a z97, its says its not supported on when i try loading it up.
I just wanted to set up a few profiles to hotkey with my AB profiles, but cant seem to get it working, i tried Easytune but it doesnt have an option to lower Uncore and doesnt seem to save the profiles properly.
Cheers.
Ive tried 2.0 and 2.1. Maybe they just didnt make this board compatible, would be a shame i like that program.
Wierd, tried uninstalling TL and Easytune, then reinstalling a few versions. Just says this model is not supported every time, i guess something on this board isnt compatible or summat.
I thought this was a decent looking board maybe i should have stuck with UDH5.
I dont suppose anyone knows how to edit the premade profiles in ET6, that would do for now i suppose untill i can find some better software. I wish AB worked for mobo settings too, would make it much easier :)
Ive managed to get ET6 working nicely for me now, i just need to find the keybind installer for it, i had it the other day, now ive totally lost it :(
In ET6 its allows you to switch between Default and energy saver on the fly, so works really well if your using offset voltage.
Scrapped that idea, uninstalled easytune and just assigned 2 windows power plans to my keyboard, dunno why i didnt think of that before.
Windows had the answer all along :)
