Gigabyte UD5`
12 Jun 2007
Here's a bit of a design flaw. Gigabyte only let you create 2 disk raid0 on the 4 port hardware raid ports. So you have to have 2 x 2 drive in raid0 vs 1 x 4 drives in raid0.
Anyway know if this can be changed?
I believe that there are 2 seperate raid controllers for the 4 raid ports hence 2 drive raid 0
I would suggest that you use the intel sata ports for raid as the intel raid controller is the better performing one
blue is the intel ports
white is the G-RAID
blue is better generally as the software is the intel matrix storage
white is the G-RAID
But blue is software raid not hardware raid? Surely hardware always beats software?
Oh and can you please take a look at my post in the Customer Service section. System wont run at 4ghz for me! :(
The Intel ICH10R and Gigabyte SATA2 (JMB322) are BOTH software RAID implementations, however, the Intel ICH10R is considerably better than the offering from jmicron...
If that's correct then I definately agree. The board indicates they hardware raid though???
