So this is my third 7950 in a month, and it seemed to be going ok for about 2 weeks, or so i thought. First of all, the core clock speed is 1Ghz, not 900Mhz as advertised on the website and the box. First time i fired it up, i got no signal to either monitor, but i just put that down to luck and rebooted, and it seemed fine after. But as time goes on, i'm getting this problem more and more frequently. Suddenly i'll lose signal to both monitors or the system will just hang. A few times also, i have had major artifacts on the bios and windows/linux start screens.
I tried a new Bios from Gigabyte's website and flashed it through the Atitool. Apparently it reverts the core speed to 900Mhz, but i flashed it and GPU-Z still shows 1000Mhz stock and current speed. I'm guessing these issues i'm having might be due to Gigabyte overclocking it too high or not enough voltage (1.25v if i can remember correctly). I don't really care about overclocking my GPU, and i'd rather have a stable card.
The problem comes in trying to reproduce the issues i'm having, since they seem so random. I can run Furmark sometimes for an hour straight without a crash. Other times it will crash within 10 mins. Same goes for Unigine Heaven or any games like Far Cry 3.
Should i RMA? My worry is that they won't be able to reproduce the issues. Or should i try to underclock it a bit? But would that even work? Since i was getting issues in bios and windows start screen, it would still be overclocked by the GPU bios right? Until it reaches windows anyway...
Getting very frustrated with these 7950's now. First two were MSI with faulty fan diode's. Any suggestions?
Btw, the cooling on the card is fine. The highest i've seen it go was 70 in Furmark, and it usually tops out at 60 in Unigine.
