gigabyte woes
theres no extra bios settings on this board, and i have the f3 bios, which is pretty recent
looks like the memory voltage is not adjustable, cant belive it, what a pile of ****
Thats strange as i always use Gigabyte boards (including some cheap ones) and theres always been an option to change the ram voltage.
well basically, thats £50 down the drain, as i wont be able to get a refund from ocuk now will i ?
press control F1 on the main bios screen and then it will display more options on the main bios menu.
edit
Taken from your motherboards manuel
The cheap gigabyte is designed for cheap ram which runs at 1.8v
I'm guessing you've got decent stuff which needs 2,1v ?
Alls well that ends well.
