I waited nearly 3 weeks to get the X570i expecting a nice quality of life improvement over the B450i/3600 in my media pc. At the moment I'm feeling pretty sick about it, this bios seems utter trash. Anyone else running this board with any advice for me?
I just cant get my head round it, there's sometimes 2 or 3 places to set the same thing, some override others, some don't seem to work at all unless other values are at auto - its a total mess. Why can i set every memory timing in two separate places? Why can I only set fabric voltage from a sub menu 6 deep that's not even in the tweaking section? If this is the improved Gigabyte bios layout they talked about for x570 then its a joke.
Its way less stable when overclocking than my B450i, memory overclocking isn't going well at all with frequent post failures above 3466mhz which the board then helpfully clears cmos for instead of just retrying training. 3866mhz 1:1 is stable on the b450i with the same timings and voltages. I'm also finding its slower in multicore testing by about 8% but about 5% faster single core (R20 5080 multicore 517 single core 9.84x efficiency).
Its way more aggressive with vcore and doesn't like to idle nearly as much as the B450i, idle power usage is double. I've gone through and set as many voltages to "normal" as possible, but nothing seems to get the aggressive boosting under control.
I'm on the shipping F3 bios (1.0.0.3) at the moment as the newer F4h bios (1.0.0.3ab) is still beta, I wanted to test with a stable release first. Ill try the beta tonight and over the weekend, but at this rate I'm really feeling like ebaying it and getting another MSI B450i as its literally half the price and so easy to use in comparison its like night and day.
I've swapped the cpu and memory sticks about between the systems, its definitely this board that's triggering me at the moment. Hopefully I'm just missing something simple as the board itself feels really high quality.
Thanks in advance for any comments/advice/moral support...
Disclaimer - I'm moving to AMD from Intel throughout (z87 itx system and 3 x99 setups, R5E, MSI Godlike and GB SOC) and have pretty much zero AMD experience in the last 10 years. Everything is watercooled and pushed hard but stable, I'm old school and do all my setup in bios, no apps.
