- 11 Sep 2008
- Co. Durham
Forgive this really stupid question but better safe then sorry, On the above motherboard do you have to remove the small backplate on the mobo to fit a TRUE cooler then put the s1336 backplate in its place or is it as simple as putting the s1336 TRUE backplate ontop if i did they make contact is the safe?
Thanks and more dumb questions will follow
