Got a Gigabyte X58-USB3 and 6Gb Kingston KHX2000c9ad3t1k3/6gx memory and having some problems.
Been toying with the voltages and XMP profiles.
Seems to run on XMP profile 1 which is 1800mhz or so and boots fine with 3 sticks.
As soon as i try XMP profile 2 which is 2002mhz it throws a hissy fit.
The memory is rated at 1.65v so even tried going up to 1.7v for the profile.
QPI voltage is auto set at 1.7v and am using the latest beta BIOS as had no luck with the older BIOS's.
Am now booted into windows at 2002MHz using ONE stick and all seems fine.
Any ideas why 3 sticks isn't playing ball?
Thanks,
Andy
Thanks,
Andy
