- 9 Mar 2008
Hi all,
I recently transferred the components of my old pc into a new case. The 'new' build worked fine for a week. However, the first time I booted it up on Friday it failed to POST, and went into an on/off loop stopping with Error Code 26h. The manual states that this is:
After reseating the RAM/GFX card/checking the power cables were firmly in place, the system booted without any problems. It ran for most of the day yesterday without any problems.
Flash forward to this afternoon - I went to turn it on and was presented with Error 26h again... After a few attempts at restarting, and after turning the PSU on and off, the board POSTed, and has since been working fine... A quick google suggests that power might be the cause of the problem, but all voltages are reported as being OK in the BIOS. I'll give memtest a go later on today.
Anyone have any idea what might be causing this?
1. If Early_Init_Onboard_Generator is not defined Onboard clock generator initialization. Disable respective clock resource to empty PCI & DIMM slots
2. Init onboard PWM
3. Init onboard H/W monitor devices
