gigabyte x670 x g ax BCLK setting
21 Apr 2015
so after much farting about trying to get my new pc to boot on a gigabyte x670 x g ax motherboard (damn you, 2 minute long parity check)
Im now greeted with the bios which is saying the BCLK set at 100.22mhz (sometimes the decimal is different ie 100.43 etc) should this not be at 100mhz by default?
it just looks odd and seems to be throwing all the full cpu and memory frequencys way off.
i had a quick look around and couldnt see anywhere to change this manually.
side note i have enabled xmp to get my memory up to its default speed of 5600mhz. (because of this odd BCLK frequency it will generally be off slightly though)
also i have tried disabling xmp and the BCLK will still be slightly off.
should i be worried that this slightly off BCLK setting will make my system unstable or is this normal?
