Gigabyte x870e Pro ice
11 Jul 2003
Telford//west mids
How's this motherboard as I'm thinking of buying it for my 9950x3d build, anyone got one.
I’ve got the non ice model with my 9800X3D, had it since November. Been relatively problem free. I like how you can save the fan curves in the bios to a drive and then load them back after a bios update. I had issues with the WiFi drivers on the Gigabyte site but used updated ones from ASUS which fixed the problem. I’ve also had some crashes when resuming from sleep which enabling memory context restore and power down in bios seems to fix.
Ok not to bad, I was looking at this or the asus rog strix model, needs to be white.
i have the x870 aorus elite wifi ice had it with my 9800x3d since early jan. ive had no issues apart from an odd stutter here and there. i can recommend it
