F6i bios..I did overclock before..but ive loaded default settings several times after, and yes after restart its 00. Now I can just load the os .. cant get to the bios also got a black screen.. but just one beep and debug says a9 which should be ok!?
It _could_ be SSD related as its probable the error happened as the BIOS was handing over to the Windows OS, could be caused by a lot of things including damaged hardware though.
Are you able to boot into windows and have it running ok.
Error code 73 should not stop anything from working I get it now and again at default bios settings and when overclock but have no problems it could just be a bios bug.
