- 15 Oct 2006
I'm slightly confused with what slots to put the memory in for dual channel even the manual doesn't make it clear to me.
In the old days you used to put one in the 1st slot and miss one out and one in the 3rd slot. Basically the same coloured slot.
The manual i think is referring to two next to each other?
Im saying this because CPU-Z is showing 1T 800mhz when it should be 2T 1600mhz.
