Gigabyte Z77N-Wifi ITX BIOS
1 Dec 2005
Stoke on Trent
Is anyone here using the F3d beta bios? Any issues with it?
Wondering if it will let me run my RAM at its rated speeds :)
I would try it,if it doesn't help anything just simple flash back to previous bios
ive never had a beta bios cause me any trouble so far,so they are safe to use/test with
Cheers, ive flashed the F3d bios to the board. BIOS screen looks differnet now lol, but still cant rum my ram at 1600Mhz :(
Ah well, ive at least managed to tighten the timings to 9-9-9-24 @ 1333Mhz :)
does it support x.m.p memory profile?
with 16gb of memory you'll need roughly 1.65v dram voltage
GA-Z77N-WiFi - F3e http://www.mediafire.com/?i226btpbftufze2 is it this beta you tried?
Yep ive tried it with the XMP profile. Tried enabling that and it made no difference. However it will do 1600 @ 1.50v as that's what I running it at in my old P67 board.
The BIOS you linked to looks like it may be newer as mine was F3d. :)
