Gigabyte Z87-D3HP Restart Issue (boot loop) or stuck at POST
28 Apr 2009
Hi Guys,
Hope you can help, i am having trouble with the Gigabyte board that was supplied as part of the "Quasar 240i" Intel Core i5 4670K @ 4.4GHz Overclocked Haswell Gaming PC Bundle from Overclockers.
The symptoms are as follows. Basically the board get stuck either in a boot loop or just at POST. I have narrowed it down to be something related to the RAM. The only way to get the PC to boot is to remove both Sticks of ram replace one of the sticks (Doesn't seem to matter which) boot the PC then shut down the PC again and add the second stick of ram and boot once more and as long i dont try to shutdown or reboot the PC is stable and works OK.
I have tried to reboot with just one stick in all the slots and this makes no difference. I have also tried different RAM and the symptoms remain.
Any suggestions what to try next?
Thanks in advance.
I didn't want to update the bios as i didn't want to lose the OC built in overclock. Having said that now that i have checked i don't think it was there anyway.
