Gigabyte Z97 SOC Force issue.
Permabanned
5 Jun 2010
Can anyone tell me what 03 on the LED display on the motherboard means please?
Every so often I can't wake the PC and it shows that code on the display.
I don't know anything about the led codes but if you're having problems resuming from sleep, perhaps your PSU isn't haswell compatible?? If so, there is some C6/C7 sleep states thingy you can disable in the bios.
