Gigabyte z97mx Lan issue
19 May 2011
Hello all. Earlier in the year I purchased the following PC upgrade from overclockers:
*CP-539-IN Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150
*MY-142-KS Kingston HyperX Beast 16GB (2x8GB) PC3-17100C11 2133MHz
*Dual Channel Kit (HX321C11T3K216)
*MB-502-GI Gigabyte Z97MX-Gaming 5 Intel Z97 (Socket 1150) DDR3 Micro ATX Motherboard
*CA-004-SF SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black
*HD-026-KS Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gbs Solid State Drive (SH103S3120G)
In the last few days I have upgraded my PC (and my laptop) to windows 10 and I have upgraded all the network drivers, since then I've been having internet issues. I am a virgin media customer and have a superhub. For some reason my superhub keeps locking up and I have to reboot it to get internet back. I called Virgin and the engineer replaced the superhub but suggested that the LAN port on my PC might be faulty. 3 hours after the engineer has left the new router has locked up again. I've disconnected the PC from the router now and I have found it seems to be working ok. Although time will tell.
My question is, could it be that Windows 10 is causing the problem or could I actually have a faulty LAN port on my motherboard (is the windows 10 upgrade a coincidence). I'm hoping it's not the latter as I really can't be doing with sending it back. Any suggestions?
Thanks in advance
Try posting in the Windows > Windows 10 forum as well, as somebody there may have come across this issue.
But check this thread too for any hardware-related tips some may offer.
Hope you get it sorted.
Killer™ E2200 gaming networking
thats your problem most likely, they are awful and screw up everything - buy a cheap intel lan card and enjoy a trouble free network
Just a heads up. There are newer Windows 10 drivers out for the Killer Network E2200/E2400 series network cards that I'm testing now.
I've been having intermittent disconnection issues on my Gigabyte Z97X - Gaming 3 using its E2200 also.
http://www.killernetworking.com/support/driver-downloads/category/other-downloads
I'm using the "Standard Drivers (no killer features)" download. Even though the webpage says it was last updated 04 August 2015, the driver is the newer version: 8.1.0.31 (28/08/2015) as found in the Killer Suite.
Hoping these drivers fix the problem.
