I have just got a G550W speaker system, my problem is that it came with a European 2 pin power cable as you know we use a 3 pin plug but on the back of the amp where the power plugs in it says 230v and we use 240v will they work with our 240v power I have put a 3 pin plug on the power cable but as I'm not sure off the volts I have yet to plug them in wanted some advice first.
Thanks
Dean
Thanks
Dean
