- 1 Nov 2022
- England
Hi there, Can Q Flash be disabled on a B850 Aorus Elite m/b
Is this so you can use the USB port for something else?
If so, it should just work as normal.
Only when you use the QFlash utility do you have to use the dedicated USB port.
Don't think you can disable the button, but it sounds like the IO shield/back plate is misaligned.
If you have got the PC up and running, just do future updates through bios.
I would probably RMA the board though.
