One of my mid-week staples is a simple spaghetti carbonara. It's so easy I wish I knew how to cook it when I was at Uni
- Fry up some pancetta cubes (or chopped up bacon) in lots of olive oil, on a relatively high heat.
- Once this is going, get your pasta on (spaghetti, penne, whatever).
- When the pancetta starts to get crispy, add a shallot or half a white onion.
- Turn the heat down and let the onion/shallot cook slowly.
- Add a teaspoon of dried rosemary
- Meanwhile, beat 1 egg in a bowl with a splash of milk.
- Grate a big handful of parmesan/pecorino onto a plate. Mix two thirds of it in with your egg, along with some pepper.
- By now your pasta should be ready. Drain it, but not too well. A little water left is ok. Put it back in the saucepan you cooked it in.
- Transfer your pancetta/onion into the saucepan and mix well. The idea is to coat the pasta with the oil you fried the bacon in. You don't want sticky pasta.
- Then mix in the egg/cheese mixture. The trick is to only swirl the sauce around the pasta about 3-5 times, any more and you will end up with scrambled egg! Don't worry if it's still a bit runny, it'll carry on cooking whilst you plate up.
- Serve into a warm pasta bowl.
- Scatter the rest of your cheese on top.
I also normally add some frozen peas to the pasta for a bit of green. Also a dollop of creme fraiche or cream is nice to add to the egg mixture -- but not neccesary.
Such an easy recipe and only takes 10-12mins.
