Hey. I know a a very similar question to this is asked frequently, but for once the answer isn't "buy more ram". This is for a virtualbox machine, which will be allowed at most 3gb of ram, but possibly less.
So, I would like to know if there are any actual benefits to using the 64 bit os over the 32. In use both appear close to identical, with 32 bit slightly easier for compatability. I suspect under identical conditions, 64 bit code is slower than 32 bit, but I do not know this.
Whats the general opinion?
Cheers
Cheers
