GL2440HM LED Monitor
20 Feb 2011
benq GL2440HM LED Monitor
hi, i was contemplating buying the BenQ G2420HDBL after reading the thread.
but have come across the GL2440HM which seems to be better.
trouble is it seems you can only get it from europe at mo.
has anybody bought one or got any info as to when itl be available here.cheers...
here are the specs-
Screen Size 24"W LED-backlight
Resolution (max.) 1920 x 1080
Pixel Pitch 0.276 mm
Brightness 250 cd/m2
Contrast Ratio 1000:1
DCR:12,000,000:1
Response Time (tr/tf) 5 ms
Display Area 531.36 x 298.89 mm
Display Color 16.7 million
Viewing Angle (L/R;U/D) (CR>=10) 170 / 160
Terminals Dual / HDMI / headphone jack / line in
Horizontal Frequency (Max) KHz 30 ~ 83
Vertical Frequency (Max) Hz 50 ~ 76
Video Bandwidth (MHz) 205
Color Temperature Reddish / Normal / Bluish / User mode
Power Consumption 35W (max)
Auto Switching Power Supply Built-in
Features LED Technology
Senseye® Human Vision Technology (plus Senseye 3)
HDCP Support
AMA
OSD Language: 17 languages
Windows 7® compatible
K locker: yes
Speakers
Adjustments Tilt (down / up) -5 / 20
Dimensions (HxWxD) 583.79 x 434.57 x 191.74 mm
Weight Net weight: 4.2 kg.
Gross weight: 5.4 kg.
Accessories (Standard) VGA / Audio cable
Product Color Glossy Black
Vista Certification Premium
Hi there,
Based on those specs you can't really tell if its any better - things you want to know are: panel type, true response time, true static contrast ratio, input lag and colour accuracy. Also, please be aware that with edge-lit LED backlit monitors like this - Dynamic Contrast Ratio numbers may be high - but they are simply not accurate. Plus most people turn DCR off in use as it is annoying.
Assuming its a TN panel then it looks very much like the G2420HDBL, I can't see it being worth ordering in from europe. Instead, spending that delivery money on a higher quality monitor like the Dell U2311H may be worth considering - here is a review.
What is your budget? The panels themselves are likely very similar on both BenQ's and with current pricing I would recommend you look elsewhere to get a little more from your money.
hi, thanx for your reply im sorry for the delay but ive been working away.
my budget is maybe max of £200 but i would hope to get a decent one below that.
On the benq website its going for 219.00 euros but im not sure what it converts to in pounds.
