glare and red eye help please
7 Jul 2006
Stoke on Trent
hi guys.
Is there anyway to get rid of the glare on the first picture, from behind the guy
and the red and white eye on the second picture
I would apreciate any help, either somebody doing it (seen some great results from the people who actually know how to use photoshop) or somebody who can give me a pointer
thanks
I set the camera up, setting wise, then turned it off, thinking I had saved the settings in the mystyle section, when I turned it back on I had lost them all, flash went back to normal (hence red eye) etc . I should have rechecked, but well you know how it is after a drink or two
You could down load a trial of Adobe Photoshop Elements which will remove the Red eye for you automatically. More worrying the the photo is the large amount of reflection from the flash in the first phot not sure how you can easily remove that.
I gave it a good attempt but the quality of the photo is just to far gone. It would take a whol intire reconstruction of the colour, let alone the face.
Not worth the time.
The red eye was equally as difficult, always is when u have massive jpeg compression. This is the best i could do without the original, and if that is the original then u have very little hope in getting it much better.
Just can get that right eye looking right,
alternatively, just make her hair better :D
problem solved.
ran the photoshop red eye removal tool on it and it doesent know what to do with the white eye , if you know what i mean
I did try to clone somebody elses eyes in but they looked very fake
Google red eye removal. There are some long winded ways of doing it that look more real. The red eye removal in PS doesn't always work well.
I had a shot at this this morning. TBH, the first photo is a bit far gone. There is no way to remove the flare without a seriouis bit of cloning and reconstruction. As the quality of the image is pretty poor, this makes it all the more difficult. In the second image, the red-eye is fairly simple to remove, but the white-eye needs completely redrawing with a brush (as ChroniC has done above, by the looks of it). Again, due to the res and the jpeg compression, this isn't easy. My goes on that looked her eyes look really weird - very hard to get it looking realistic :(
^ LOL at the hair :cool: (though the other eye still looks a bit spaced out. Cover both eyes with hair :rolleyes: ?
wrong use of the rolleyes dude. I could take that as an insult.
thanks for trying
as i said earlier, the stupid ass camera (yeah i knwo workman - tools) reset to its default setting
which is HQ(hah hah)quality
it does Tiff, Shq, Hq and your (having alaugh if you want to ever use this) Mq
so the original is almost as pixalated as the one i posted.
There were half a dozen reasonable ones, out of the 20 or so I took (those two not counted in the half dozen)
I picked on those for here for two reasons, one I would have liked them without the obvious problems, and two in th ehope that somebody woudl be able to get rid of the white eye.
Incidently. I also reduced the saturation on my version (notthe ones i posted) to reduce the....red faced result of too much alchol on the night, is that the right way to do it, or is there a more impressive way?
