Global variable C++ driving me nuts!!!!
26 Jun 2003
North West
I have a variable:
int view;
and a few files:
main.cpp
main.h
file1.cpp
file1.h
file2.cpp
file2.h
Now each file needs to access the one global copy of view, so I tried putting in a global.h file that is included on each header file above. Now I get the error:
In file included from include/main.h:6,
from src/main.cpp:17:
include/globals.h:9: redefinition of `int view'
src/main.cpp:15: `int view' previously declared here
In file included from include/file1.h:9,
from include/main.h:7,
include/globals.h:9: `int view' previously declared here
Ive tried loads of combinations and I cant get it to stop giving me this error!
Any ideas?
Have you put the preprocessor code to stop it including multiple versions?
put somethings like this in the global.h
at the beginning:
Code:
#ifndef _GLOBALH_
#define _GLOBALH_
then at the end of global.h
Code:
#endif
This works most of time for me but if someone has a better way... :)
Yup - sounds l;ike you need some include guards, as suggested.
Global variables are a Bad Thing though - you should consider encapsulating them into a singleton class.....
I havnt put stuff into classes yet, but I will be.
I forgot about that IFDEF stuff. Ill give that a try
Thx
