** GLORIOUS GMMK PRO 75% PRE-BUILT - PRE-ORDER NOW **
OcUK Staff
23 Feb 2015
Overclockers UK HQ
You can now buy the excellent Glorious GMMK Pro 75% pre-built!
For those of you who don't know we've been selling the build your own versions, but now you can grab them pre-built!
There is only one flavour as pictured below with white caps, black frame and black coiled cable. You can obviously personalise with the other accessories available.
It also comes with:
4 x Additional Mac keys
1 x Novelty ESC key
1 x Black Glorious Coiled Cable
1 x Glorious Padded Keyboard Wrist Rest
1 x Glorious Keycap Puller
1 x Glorious Switch Puller
You can pre-order below and stock should be here around end of April/May!
Glorious PC Gaming Race GMMK 75% USB Gaming Keyboard Fox Switch White Keycaps Black Frame Pre-Built UK Layout @ £319.99 inc VAT
TKL 75% keyboard, Pre-Built, Glorious Fox switches, Per-key and side RGB lighting, CNC milled aluminium case, Hot-swappable
PRE-ORDER £319.99 inc VAT.
ORDER NOW
These keyboards are amazing and definitely worth the price.
It's quite hard to put into words.
They are so planted, built wonderfully and typing on them is lovely.
These keyboards are easily worth the money!
- They are heavy and so planted on your desk, they don't move around like some keyboards.
- They are beautiful to type on out of the box, but you can also customise your typing experience and aesthetics with various switch plate mounts, switches, keycaps and top-plates.
- Great price for a high-end entry level CUSTOM Mechanical Keyboard. (Higher end custom keyboards can be £400+ for a chassis alone)
My keyboard has rubber feet and doesnt move on the desk
mines great to type on out of the box with cherry brown switches
mine doesnt cost £319
mine doesnt have a novelty escape key
mine doesnt have half the keyboard missing.
I will stick with mine thanks :p
Each to their own. I currently have a Ducky Sakura with Cherry Browns. I'm also currently building and modding my own GMMK Pro after typing a stock one and a modded one also... The typing and sound difference is noticeable. Also, it's a hobby :D
These GMMK Pro keyboards are excellent, especially if you get some decent aftermarket stabes like the Durock v2's and mod them, plus use the PE foam mod on the board. I've had boards like the Ducky Shine 7 which is one of the best commercial boards available and the GMMK Pro correctly set up will destroy that for the typing experience :)
I think the GMMK Pro frames are the best foundation out there to build from.
Definitely in quality terms, but also style.
I built my GMMK pro up from a barebioones kit and this price is very good. The keyboards are impeccable, amazings build quality and a great way into the keyboard building enthusast sector. I used to spend around £100 - £150 on keyboards tops and they would be corsair or logitech. Those brands both make functional keyboards but i will never go back to them again, these are on a totally different level. My only gripe was teh stabs but that is easy fix.
I get that paying this sort of price for a keyboard is not for every one, unless you have tried one saying these are to expensive is just not true
i dont doubt that its not a great or amazing keyboard, but that sort of money in my budget is more likely to go towards a CPU etc.
Not the best foundation, but the best for ease of access.
OCUK Need to get more switches in too, like Gateron Ink Yellow's and Neopolitan Ice Creams etc etc...
What switches are you using? I'm planning on running (for now) Kailh Box Blacks with Durock V2 Stabs, both lubed, and a brass plate too...
i am currently using the Tencsee Ice Candy switches with Durock stabs all lubed. I went for a FR4 plate and using a mixture of steelseries pudding keycaps and Tai Hao rubber keycaps
+1
Any thoughts on customising this? I feel you could sell a fair bit more if you gave atleast keycap colour choices. The white just wouldn't work for me. Nothing white ever works for me lol.
